TeamCenter 8 Search Results Cleanup
In TeamCenter 8, the program numbers the search result. I am trying to clean up my search results, and this comes from the older versions of TeamCenter where I was told to clean out all my search results regularly.
Then, I go to the window of "Open Items" and click on "Close All", and then manually close the rest of the search results, the "Item ID (XXX)" maintains the last number, and currently the "XXX" is in the hundreds. Here is my question, is it necessary to get that "XXX" number reset to zero or is it ok for it to just keep adding up all my search results? And, if I am to reset that "Item ID (XXX)", then how do I do this?
Thank you for any information and help on this.
