coating for drinking water pipes
Hello all,
I am designing a buried pipe system for drinking proyect with carbon steel pipes. Could anyone to help me to select the correct coating (internally and externally)? Do you recomend me any good bibliography or design guide?
Thanks in advance.
Thanks in advance.
RE: coating for drinking water pipes
http://10statesstandards.com/index.html
1. AWWA C200 Steel Water Pipe 6 Inch and Larger
2. AWWA C205 Cement-Mortar Protective Lining and Coating
for Steel Water Pipe-4 Inch and Larger-Shop
Applied
3. AWWA C206 Field Welding for Steel Water Pipe Fittings
4. AWWA C207 Steel Pipe Flanges
5. AWWA C208 Dimensions for Fabricated Steel Water Pipe
Fittings
6. AWWA C602 Cement-Mortar Lining of Water Pipelines 4-
inch and Larger-In Place
7. AWWA M11 Steel Water Pipe - A Guide for Design and
Installation
Does anyone ff is it in Europe??
The European practices as well as the world practices are similar to the United States practices. However, the water usages are typically much lower in the rest of the world.
Some of the countries in Europe have their own standards. The UK and Russian Federation for example have their own standards.
