Retaining wall-drained or saturated
One design firm that I worked for had had a policy to design retaining walls for undrained/saturated condition, even if a drain was shown on the drawings. I was told that the reason behind that was the fact that the drain may get clogged and, with rain or high water table, the soil may be saturated.
Is this a common practice to simply ignore the drain?
RE: Retaining wall-drained or saturated
Also, what confidence do you have over the landscape and grading?
It is a judgement call.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
If you want to improve your drain and reduce the possibility of clogging, you may cover your perforated drain pipe with the modern Geotextile as there are types can be used for such purpose. You can find lots of details in this free book: 'Geosynthetic design and construction guidelines' from US department of transportation.
