Effectiveness-NTU graphs/equations
Does anyone know of any sources for effectiveness-NTU graphs (or equations) for somewhat out of the ordinary heat exchanger configurations (i.e. not only cross, counter and parallel flow).  I am looking for something that would handle a serpentine crossflow configuration where the serpentines run parrallel to the flow direction and could be either overall counter flow or overall parallel flow.  Hope this makes sense!  Thanks...
RE: Effectiveness-NTU graphs/equations
Heat Transfer by Holman or Incropera&Devitt.
You can try Compact Heat Exchangers by Kays and London.
K. Stifle, P.E.
For any heat transfer problem: VDI waermeatlas.
Cees-Jan
I'll recall you what my professor of thermodynamics said in the old times: the difference between an arithmetic average temperature difference and a logarithmic average temperature difference is normally only a few percent!
That is to say that very simple equations are almost always sufficient to figure out and even to design a heat exchanger.
prex
http://www.xcalcs.com
Online tools for structural design
Try this book:
The fundamental of Heat and Mass transfer/ or Introduction to Heat Transfer; by Holman or Incropera&Devitt.
Both are basically the same book with one thermo chapter difference.
Sometimes MIT would release their courses on the web for students; try there for any information.
Good luck!
