Disadvantage of using Girt Joist in leu of Stl beams for perimeter framing
What , if any, are the disadvantages of using Girt joists for perimeter framing.
I've heard there are drag strut issues, not sure if thats related to the connnection between the perimeter stl deck and perimeter framing.
Also, has anyone used Girt joists to "make" CBF's. I've seem Girt joists baced with tension members, but I have not seem them used in compression!
RE: Disadvantage of using Girt Joist in leu of Stl beams for perimeter framing
I suspect you have a good idea of your question, but it's not clear to anyone else.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Michael.
Timing has a lot to do with the outcome of a rain dance.
