Electrical Routing Hidden Lines
I just finished our companies pilot usage of the electrical routing versus splines and tubes. This application will be great for us, however I'm finding a snag when creating the harness installation drawing. For some reason the sweeps do not hide geometry that is below and I have to continuously use view dependent edit. I have tried every setting of view style>hidden lines to no avail. If I grab the center line of the routed harness and put a tube on it, that tube hides edges that are below it. Are electrical sweeps not calculated the same as other modeling solids during hidden lines?
This could potentially add painful hours of manually hiding edges and line segments on a drawing so if there is a known bug or fix coming that would be helpful to know.
bmolz
bmolz
RE: Electrical Routing Hidden Lines
Can you provide a simple example ? ( I.e create a cable which is above a simple block and post it in a zipfile )
Tomas
Anyway the answer was what I thought, just didn't take time to isolate and simplify.
Thanks anyway.
