User can't delete components
Has anyone seen a case where a user can't delete components from assemblies.
On using right click and delete in the assembly navigator, NX simply responds "component deselected" and the part remains.
The user owns the assembly, and I repeated the problem by creating a very simple test assembly on his machine.
Using NX7.5 and TC 8.3.
Thanks in advance, Carl
RE: User can't delete components
Let us know if you need help with that.
The same problem exists of the components are in a reference set. In older versions (pre-NX) you could delete the components but end up with database errors because the reference set would not update to reflect the component deletion.
Ben Loosli
Its almost as if "delete" is acting as deselect instead.
I'll send it to GTAC this morning see if they can help, cheers Carl
Also make sure that you are actually in the Assemblies application, and not just in Modeling.
thread561-326620: UG nx 7.5.5.4 Cannot delete components out of assemblies
www.nxjournaling.com
Will see what he comes back with.
Thank you, Carl
From Carl
