Journal - CreateImage
Hello Eng-Tips: I manage to add some code lines to orient a model (standard views) and create an image by a journal but in the end result (image.jpg) the window "Work in process" make a photoboom, is there is a way to avoid/hide it apparence?
Attached you will find the journal.
RE: Journal - CreateImage
www.nxjournaling.com
