Centerifugal Pump Pipe Design for 24hrs.
Recentely, we faced problem when we run our water supply sestem to our tank. Our system consists of 5 tanks which they can be suction/return tanks depending in the valves. The suction lines of each tank connected to the suction header then to the pump suction inlet. The discharge lines connected to the suction line befor the suction header. Now, if we operate the system in circulation mode from the same tank, we have problem that the pump & pipes become very hot. But if we transfer a water from tank to different tank there is no problem. Our desire is to continued pumping 24hrs from the tank & returned back to the same tank. Could you please help in this issue?
RE: Centerifugal Pump Pipe Design for 24hrs.
In order to have circulation through the tank, you need one nozzle for the inlet to the tank, and one nozzle for the outlet. Without that, you'll have no circulation through the tank.
In this case does our system suffer from cavitation due to high fluid temperature? What extera causes if its true.
