Drawings: Material properties from the part
Hi, I have a question:
1. If I want to have the part's materials properties in the drawing ($PRPSHEET:{Material}), in the part, I have to go to File>Properties>Custom and select the Material under property. Why is this not populated automatically? (I am using a custom material, if it matters)?
Thanks.
Thanks.
RE: Drawings: Material properties from the part
The best you can do is edit the part template and add the material property an save it. Now next time you make a new part and assign material to it, this property will get automatically updated and you can link to it in the drawing.
Deepak Gupta
CSWE, CSWP, CSDA
SW 2012 SP5.0 & 2013 SP 1.0 EV
Boxer's SolidWorks™ Blog
SolidWorks™ Rendering Contest
http://help.solidworks.com/2012/English/solidworks...
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Diego
Not sure if this is what's confusing you but, the property the drawing is referring to is not the "Material" in the part feature tree. It refers the "Material" property specified in the part File Properties dialog box. There is normally no link between the two.
