Non Linear Analysis
Non Linear Analysis
I am working on a non-linear contact problem in Ansys Apdl. In the material models i am trying to input strain and stress values for the multilinear plasticity. In the project description we were given several points ploted on a graph of "engineering stress and strain". The 0.2% yield stress has a value of 735 MPa and the young's modulus 200GPa. Now if I want to put the points of "stress Vs plastic strain" should i convert the "engineering stress and strain" points from the graph given to "true stress and strain"? If that's so then here are my calculations for one point.
The next "engineering stress" point provided after the yield stress is 738Mpa and the equivalent strain point is 0.848%
i know that eps(true)=ln(1+eps(eng))
and that Sigma(true)=Sigma(eng)*(1+eps(eng))
therefore eps(true)=ln(1+0.848)=0.614%
and Sigma(true)=738*(1+0.00848)=744.26MPa
The true eps(elastic)=Sigma(true)/E=744.25/200000=0.00372
The true eps(plastic)=eps(true)-eps(elastic)=0.00614-0.00372=0.00242 or 0.242%
Is my thinking correct?
Thank you in advance
RE: Non Linear Analysis
True Stress/True Strain is rarely used in engineering applications and is generally confined to the laboratory and the scientific endeavors of PhD's.
I will say two things here. Firstly, depending on the level of plastic strain you observe in your analysis, you may have to convert from Engineering to True strain (generally > 5% as a rule of thumb). Run your analysis to determine this first using your Engineering data - if the total strain is greater than 5% then consider converting. Generally I would not call the use of True stress/strain a rarity, and for some applications this would be considered extremely important (such as metal forming).
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
