Possible to convert 2D sketch to 3D model?
Hey guys,
I have a 2D drawing dimensioned as a 3D part in the sketch toggle, but no 3D model made. Is there an easy way to have KeyCreator convert the 2D drawing to a 3D model? Is that possible?
Thank you for any insight you can provide.
-Eric
-Eric
RE: Possible to convert 2D sketch to 3D model?
I thought some modeling programs could do that with the click of a button, but I may be mistaken as it has been a while, and I am pretty unfamiliar with KeyCreator.
Very simple example: Say I have a 2D sketch of a 3D cube in layout mode, without actually making the 3D part beforehand. Dimensions and views are created for 3 sides of it, so in theory it should be possible for the program to take those givens and run with it and make the cube itself as a 3D part without having to re-sketch and make the cube myself. I could see why this would be much more difficult for complicated shapes, but don't see why it would be impossible.
Again, thank you for any help you can give on the subject.
-Eric
