Opening Ordnance Survey Landform PANORAMA map files into Solidworks
Has anyone ever tried and had any success in opening any of the Ordanance Survey's Landform Panorama map data into solidworks?
The download is huge so I have attached an example map from the file.
Ideally I would like a part in Solidworks representing the topographic map data in the file.
It's something I keep revisiting and failing miserably with! The downloaded data is in dxf format which sort of opens but I can't convert it to a part or surface. I have tried various other pieces of software like SketchUp which opens it but then also fails. Any suggestions?
Or if anyone can recommend a way of getting topographic maps converted to parts I can use in Solidworks? (I have managed to rip the data from Google earth which I can get a 3d surface in to Google SketchUp but can't convert it to solid works).
Thanks for any advice
RE: Opening Ordnance Survey Landform PANORAMA map files into Solidworks
Import the DXF into a drawing and copy thegeometry into a new part sketch.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
From what I can tell, to use that file, you'd need to create an inordinate amount of 3D sketches to get your representative heights and then build surfaces from them. Given the size, I'd say you need one hell of a computer and weeks of time to do it.
Jeff Mirisola
My Blog
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
To get it out to Solidworks, you can use a ruby plugin (Su2STL) to generate an STL file from the terrain surfaces, which can be imported into SW.
Solidworks will import the map as a drawing fairly well (only the 3rd layer is needed) for the contours. But then the height information is lost and the sketch doesn't behave very well. Annoyingly importing the 3rd layer as a 3d part only partly works and doesn't import all the contours. I can't do anything with it anyway. Though I guess I'm probably missing one of the more obscure Solidworks commands. I think it falls down with the scale too as I believe SW can't deal with parts over 500m
I have been having a little more joy importing from Google SketchUp, thanks to the su2stl plugin (thanks for that!)
After using SketchUp to get a topography I can then Export it as an STL.
I can then import it to SolidWorks as an 'STL Graphic' or as a 'mesh' but I again I can't do anything use full with these (create a surface or a part). Probably missing something SW can do as this is all uncharted territory for me. I have attached a part file of the STL import from SketchUp in the two ways I can import, STL graphic and mesh if anyone fancies a look!
Incidently I have also tried making a contour map with SketchUp following this tutorial but I can't get much joy with that either.
Thanks again for any suggestions!
