I have been offered studs in 17-4PH
I have been offered studs in 17-4PH Double Aged but at H900 +H900.
Will this steel be resistsnt to SCC in this condition? or should I use H1150 + H1150
RE: I have been offered studs in 17-4PH
If it is important then keep looking.
These could be re-aged.
Plymouth Tube
Custom 450 stainless steel H1000 and above
Custom 455 stainless steel H1000 and above
15-5 PH stainless steel H1000 and above
PH 14-8 Mo stainless steel CH900 and SRH950 and above
PH 15-7 Mo stainless steel CH900
17-7 PH stainless steel CH900
Stockholders over here charge like a bunch of wild horses for any 'specials' and this tends to dominate choice.
One company has benn using 17-4PH for smoe years without any reported problems but I will try again to find the 15-5PH.
I think I did say 'one' Company.
My problem is that the environment that the studs will be used in differs greatly and it would be difficult to simulate actual operating conditions.
Having said that and AALCO publication states that 17-4PH Corrosion resistance is similar to that found in grade 304 stainless steel.
In warm chloride environments, 17-4 PH is susceptible to pitting and crevice corrosion. When aged at 550°C or higher, 17-4 PH is highly resistant to stress corrosion cracking. Better stress corrosion cracking resistance comes with higher ageing temperatures.
Corrosion resistance is low in the solution treated (annealed) condition and it should not be used before heat treatment.
http://www.aalco.co.uk/datasheets/Stainless-Steel_...
Other data sheets give a little more information:
Corrosion Resistance
Alloy 17-4 PH withstands corrosive attacks better than any of the standard hardenable stainless steels and is comparable to type 304 in most media.
If there are potential risks of stress corrosion cracking, the higher aging temperatures then must be selected over 550°C (1022°F), preferably 590°C (1094°F). 550°C-1022°F is the optimum tempering temperature in chloride media.
590°C-1094°F is the optimum tempering temperature in H2S media.
The alloy is subject to crevice or pitting attack if exposed to stagnant seawater for any length of time.
It is corrosion resistant in some chemical, petroleum, paper, dairy and food processing industries (equivalent to 304L grade).
semi-austenitic PH grades (austenitic when annealed); 17-7, 15-7 is the Mo bearing version.
If you are not welding or using thick sections (>2") then 15-5 has no real advantage over 17-4.
Plymouth Tube
