Ideal Requirement of Codes & standards for a Fertilizer plant
Back to Basics...!
Can some one tell .. where i can get the comprehensive list of codes & standards likely to be used in a Ammonia-Urea fertilizer plant..!
Query may look silly .. however, to us it is very critical to know the correct standards to be procured...!
RE: Ideal Requirement of Codes & standards for a Fertilizer plant
In the USA, ASME B31.3 for pipe, ASME Section VIII for pressure vessels and heat exchangers, AISC for Structural Steel, NFPA for fire suppression systems, etc.
