missing edges in view (Drafting mode)
I don't understand what is the reason of this problem. I changed something in settings and now I dont rememember what was that but when I am making View in Drawing mode then in the view "midle -edges" of cylinders, surfaces... disappear. I used before option UPDATE VIEW> DRAWINGS > VIEW PREVERENCES> SILHUETTES (or FILE> UTILITIES > CUSTOMER DEFAULTS...> SILHUETTES) and thats helps but now there is something wrong.
How should I switch to get visibile virtual surface edges in the View.
Best Regards.
RE: missing edges in view (Drafting mode)
I'm not sure if I understod your problem correctly, but I assume that you've checked your: view (RMB on view border) -> Style... -> Silhouettes (on General tab)?
/Lars
Refresh the view and see if they show up
Today I opened the same drawing and I did what you suggest and It is working. I must admit that I tried this yesterday but there was no change in the view. I suppose the problem was somewhere else and Just restarting Nx program helps because now SILHOUETTES options work properly. :)
Thanks very much for answer.
Best regards!
