Galvanized pipe in underground piping
Can we use galvanized pipe with wrapping in underground piping?
RE: Galvanized pipe in underground piping
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
Of course. For underground galvanized pipe wrapping is important.
first of all thanks for your reply.
I have seen underground galvanized pipe which has been seal welded.is it ok?
it will rust, is that ok?
what pressure?
what fluid?
soil resistivity?
water table depth?
amount of rain?
design life?
pipe wall thickness?
type of coating?
Does not it cause to galvanic corrosion?
your post directly relates to design and desired design life. galvanized iron is not typically used underground, welded or non welded. doesn't mean it cant be done if the conditions warrant. if your soil is not highly corrosive and your pressure is low and you select a thick pipe, properly coated and wrapped and you have a 5-year design life, than go ahead and use galvanized iron - it might be acceptable. if you have corrosive soil, high water table, high pressure gas service, 100-year design life, than use something else.
