nx X-form - polygon edition
I have a little question: How to work with X-form command (in NX 6.0)?
I will be a more precise. I have a problem with selection surface for modification. When I try use X-form on the surface and choose from window "select object" nothings happen ;-( (image below)
Sometimes It helps commands called "Remove Parameters" which unfortunelly remove model history.
Is there anyway to handle it with this issue?
Peace
RN
Peace
RN
RE: nx X-form - polygon edition
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks JohnRBaker for reply.
In the other words: if I have opportunity to use X-form in NX 6.0 I must build my model with tools from "FreeForm Shape" Module?
Regard
RN
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks JohnRBaker for your help.
Peace
RN
