Aeroelasticity (SOL144) - Problem with constraints
Hi everyone,
I have a problem running my static aeroelastic analysis problem.
It consists of one wing represented as different beam elements along the span of the wing (has a kink).
To the nodes connecting the spanwise beams also always leave a beam towards the leading edge and one to the traling edge.
I have clamped the root (Node 201) with SPC1 1 1246 201.
And nodes 101 and 301, which are the leading and trailing edge at the root with SPC1 2 246 101 301.
Further I have specified a SUPORT 35 201 to perform the TRIM analysis.
I think this should sufficiently constrain the model. However I'm getting the following error.
I have tried to run a modal analysis with the same structural model and this runs without problems. I'm guessing it goes wrong
somewhere in the definition of the splines. I'm currently using SPLINE4.
What I find weird is that nodes 209 - 220 are located from the kink to close to the wing tip, along the elastic axis.
Why is there a problem only at those nodes and not the others?
I will check tomorrow if I can perform a Flutter analysis with only one aerodynamic surface and spline defined and no elevator.
I have attached the .bdf and .f06. Hopefully somebody can give me a hint.
Thanks anyway!
CODE -->
*** SYSTEM INFORMATION MESSAGE 4159 (DFMSA)
THE DECOMPOSITION OF KLL YIELDS A MAXIMUM MATRIX-TO-FACTOR-DIAGONAL RATIO OF 8.627062E+07
*** USER WARNING MESSAGE 4698 (DCMPD)
STATISTICS FOR DECOMPOSITION OF MATRIX KLL.
THE FOLLOWING DEGREES OF FREEDOM HAVE FACTOR DIAGONAL RATIOS GREATER THAN
1.000000E+07 OR HAVE NEGATIVE TERMS ON THE FACTOR DIAGONAL.
USER INFORMATION:
THIS MESSAGE MAY BE IGNORED IF NO GRID POINT IDS OR HIGH RATIO MESSAGES APPEAR IN THE TABLE ON THE NEXT PAGE.
1 MSC.NASTRAN AEROELASTIC JOB CREATED ON 30-NOV-12 AT 18:31:27 DECEMBER 1, 2012 MD NASTRAN 12/15/10 PAGE 8
UNTITLED.SC1
0 SUBCASE 1
0
GRID POINT ID DEGREE OF FREEDOM MATRIX/FACTOR DIAGONAL RATIO MATRIX DIAGONAL
209 T1 2.32532E+07 2.46890E+16
212 T1 2.68200E+07 2.46728E+16
212 T2 8.62706E+07 8.00587E+15
214 T1 1.70589E+07 2.46624E+16
214 T2 2.53534E+07 8.03312E+15
217 T1 2.55754E+07 2.46445E+16
217 T2 5.81368E+07 8.07818E+15
220 T1 2.59770E+07 2.46251E+16
220 T2 5.01106E+07 8.12882E+15
*** USER INFORMATION MESSAGE 3035 (SOLVER)
FOR DATA BLOCK KLR
SUPPORT PT.NO. EPSILON STRAIN ENERGY EPSILONS LARGER THAN 0.001 ARE FLAGGED WITH ASTERISKS
1 4.9240492E-14 -2.6321411E-04
2 4.9240492E-14 -2.2796631E-02
^^^ USER FATAL MESSAGE 9050 (SEKRRS)
^^^ RUN TERMINATED DUE TO EXCESSIVE PIVOT RATIOS IN MATRIX KLL.
^^^ USER ACTION: CONSTRAIN MECHANISMS WITH SPCI OR SUPORTI ENTRIES OR SPECIFY PARAM,BAILOUT,-1 TO
CONTINUE THE RUN WITH MECHANISMS. I have tried to run a modal analysis with the same structural model and this runs without problems. I'm guessing it goes wrong
Thanks anyway!
RE: Aeroelasticity (SOL144) - Problem with constraints
BTW, have you tried using param,maxratio,1.+8 on your input deck? MSC does recommend using maxratio in the order of 1.+7 to 1.+8 on most production models. I don't think the loss of one significant digit is going to affect your solution accuracy!
First of all, fortunately I've been able to solve it over the weekend.
I found several errors which may have caused the problem.
One is the fact that the research student of whom I got the model represented rigid beams as normal beams with a Younghs modulus of 10^20 GPa, I guess that the 10^10 order of magnitude with the other beams is not appreciated by the solver.
An other problem seemed to be the aerodynamic coordinate system which had the Z axis pointing upwards just as the reference coordinate system. This caused a negative angle of attack and negative pressures which didn't made sense.
Thanks for the proposal to contact MSC but from their site I found that only commercial customers can use the support.
However, they seem to have some support personnel on their forum.
Kind regards.
