I can't get my centerlines to look good
3
How do you get centerlines on a SolidWorks drawing to simply have a LONG-short-LONG piece, and that's it!?? (not keep repeating).
Is there any easy way to get them to look right? Thanks.
Jack Lapham, CSWP
Engr Sys Admin
Dell M6400 Covet (24 Season 8, Ep 22)
Intel Core 2 Duo T9800, 2.93GHz, 1066MHZ 6M L2 Cache
8.0GB, DDR3-1066 SDRAM, 2 DIMM
1Gb nVIDIA Quadro FX 3700M (8.17.12.5896)
W7x64 | sw-01: 55.92
SolidWorks 2012 sp3 x64 & EPDM sp2
RE: I can't get my centerlines to look good
Grab the end and move it?
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Quote (SnowCrash)
Then I end up with LONG-short-LONG-short-LONG-short-LONG. I just want a slightly more stretched out LONG-short-LONG.
Jack Lapham, CSWP
Engr Sys Admin
I've been doing this for a LONG time and in my opinion any centerline over a certain length should repeat the long-short-long sequence, as shown at the top. I see nothing wrong with that at all.
The repeat pattern of a centreline should be consistent, otherwise it would be classed as a different type of line.
However, custom line patterns can be created at Tools > Options > Document Properties > Line Style
