Process Water Loop
Process Water Loop
Could anyone provide me with a design methodology that they used when selecting materials (pipe mainly) for a process water loop according to the B31.3 specification? I have a prcoess water loop that has been in service for 30 years that will soon be replaced, traditionally we would just replace the components with what came out because it served us well for 30 years. Although, the current system is made out of 1000+ft 3" copper and we cannot spend that kind of money. Can anyone help me understand the proper steps in determining a suitable replacement? I would like to use a 3" sch 40 buttwelded A36 pipe but I am worried about corrosion after so many years...
RE: Process Water Loop
Water applications like this would normally use either ductile iron or PVC pipe. For industrial use, you may also consider using FRP or HDPE.
The Contractor that you use may have the materials to do this project or expertise with a particulare piping material. You should consult with the local Contractor. The layout of the piping system will also have some impact on the cost as well.
You probably will not obtain an acceptable service life if you just use plain steel.
