FRT and islanding
FRT and islanding
if an inverter supports a power system by feeding it reactive current during a fault, doesn't that inhibit the anti-islanding feature of the inverter? please help me understand FTR(fault ride through) and anti-islanding!!
RE: FRT and islanding
For a short circuit at a transformers terminals the only induction in the circuit is the transformer itself and reactive current flows as a result.
Bill
"Why not the best?"
Jimmy Carter
The LVRT requirements could be summarized in the following:
- The generation unit should stay connected to the grid during a certain period of low voltage of a certain depth (ex. 125 ms for a voltage drop of 100%)
- The generation unit should support the grid during the period of voltage drop by injecting reactive (capactive) current into the source of the dip.
- As a consequence the generation unit should be stable in the post event operation.
The requirements of FRT are different from country to country and they are stated in the grid code of each transmission system operator (TSO) and usually they are also used when generation is connected to the distribution level. around 8 years ago there was no such requirement since generation connected to the grid through inverters was only a negligible part of the system and their disconnection or islanding during a voltage dip would not have affected the corresponding system. However today with 500 MW wind farms connected all over the network these wind farms should remain connected and provide support during a voltage dip.
