Pad Foundation Design
Hi Guys
I have a 100x100mm SHS colum with a downward force of 185.95kn the ground is solid rock at about 1100mm deep
what size pad foundation would i need
RE: Pad Foundation Design
This is a simple calc and you shouldn't need help from this forum to figure it out.
I have worked out the Bearing pressure but i am not sure of the bearing capacity of the rock
