API PLANS Applications
Hi guys !!!
I want a reference that explain how to choose a plan for my mechanical seal, application of them and have some examples for industrial applications of them ? because I know some general applications and they are not enough for me.
Thanks.
RE: API PLANS Applications
Can you provide us with the application you have? Your question is very general and for me not clear! There are API reference booklets you can get from the major seal manufacturers but they don't tell you how to select piping plans. That is based on the seal selection process and experience
Cheers
api 682 will be a good guide...
The link mentioned in ctran03 is a good one for selecting api plans for mecanical seals with some field examples. LB
I will provide you an outline with the common API plans that are used for liquid seals.
Single seals
Horizontal pump
Plan 11
Veritcal pump
Plan 13
Boiler feed water
Plan 23 includes pumping ring and throat bushing
plan 62 at the atomsphere side
coking and crystallizing
Double/ Dual seals
Flashing hydrocarbon
plan 52
zero emission
plan 53A (plan 53 b and c)
