Pro/E Creo2 export -> NX 7.5 import
a potential sub-supplier of ours is using Proe Creo2 and they make sheet metal parts. We on the other hand are using NX 7.5 and would like to STEP import their models into our design. Previously they had an older version of Proe and we were using NX 6.0. Currently the co-operation is facing a export/import breakage and our work is not progressing.
Do any of you have a working workflow for exporting sheet metal models from Proe Creo2 into NX 7.5? The preferred format is STEP but any other suitable format can be considered. Note that we want solid models for FEM purposes, not a bunch of separate bodies/surfaces (NX import "Sew surfaces automatically" did not work here, however it did improve the situation somewhat).
RE: Pro/E Creo2 export -> NX 7.5 import
While I can't speak for the support of Pro/E Creo2 formats (translators are not my area of expertise), we do offer Direct Translators for importing Pro/E data, both part files and assemblies, into NX.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Actually we figured out a solution almost right after I posted here.. ;) The solution was to export from Creo2 into an older version of Proe, and then perform the STEP export from there. Of course such a solution is not the ideal one but for now we go with this.
Thanks!
Sounds like the STEP translator with Creo2 is writting bad data. STEP has not changed its spec in a few years so you shouldn't see any differences in a Wildfire vs a Creo STEP file.
What version of Wildfire did you use to create the STEP file for NX7.5? What method did you use to open the Creo2 file in Wildfire, STEP, neutral, GCRI?
Ben Loosli
as I wasn't present when they did all the exporting, I am unaware of exact versions. During the process we were quite sure it was indeed Creo2's STEP exporter that was causing the issues. This seems odd, since as you also mention, the STEP spec should not have changed.
However, we also tried importing their Creo2 STEP files into Ideas, and this quite surprisingly worked! But for NX 7.5, they needed to go through an older Proe..
