HI, All, I am new to Pro/Mechani
HI, All,
I am new to Pro/Mechanica. I am trying a simple practice problem with composite shell elements.
I have a solid thin plate. Since I can not use "shell pair" as I can not assigned laminate property to a "Shell pair", I try to use the just the top surface. I assign the laminate property to the top surface. NOw when I try to mesh the surface, I always get the solid mesh over the solid plate rather than the shell element on the surface I need. Under the "Mesh" menu, I only see "Solid" or "Boundary" as options, with no options such as "surface" or "quilt". Anybody has any idea? Thanks a lot.
RE: HI, All, I am new to Pro/Mechani
I know this was posted a long time ago, but this is such an easy and powerful thing to do in Creo Simulate that others should know about it! :)
