Limestone Teatment
Limestone Teatment
Limestone Teatment
I am passing iron rich ground water through a tank filled with limestone prior to aerating the ground water.  The tank has a pump in it which is fouling every 14-20 days.
The limestone does the job without the need for chemical dosing - yet the method is not very good.  Does anybody have any ideas or alternative methods of using limestone to increase the CaCo3 of the water.
RE: Limestone Teatment
Perhaps dose the water instead ... have a slipstream of raw water dilute water than has gone through the lime?  Are you calculating LSI values of water before and after lime?  LIS of +2 or more can be expected to cause scale, and LSI will rise with temperature, too (ie: in pump).
Hmmm.. Good luck
