Hole Patterns
Hole Patterns
Morning All,
Apologies if this has been answer, but couldn't find anything. I'm doing a hole pattern, and like anything i have two c/bores and two dowel holes. Is there anyway to put a diagonal pattern in? For example my drawing show 1 hole positioned from an edge (datum hole), then one hole positioned at 30mm in X and then 45mm in Y (so a diagonal movement) and the same on the dowels. But i can't seem to find a way. I can suppress the two unwanted holes, but my customer doesn't allow suppressed features.
I know I could rotate the WCS, but there's obviously the calculations that go with it, and when you get angles of 36.5000978 it's not ideal
Any help would be great!
Cheers
Cheers
RE: Hole Patterns
MZ7DYJ
RE: Hole Patterns
RE: Hole Patterns
Picture attached. I've created seperate holes in this instance, but you can see what i'm trying to acheive.
RE: Hole Patterns
For that particular shape you could use a circular array. See attached.
RE: Hole Patterns
Again thanks for that little tip.
RE: Hole Patterns
