Problem with Cache Activation
Hi
We work on large assemblies and so work with the cache system on. We also work with "Load Referenced documents" switched off and only load the components as needed.
Being a large assembly, there are Catproducts with other Catproducts as components. When one of these component Catproducts is loaded in the top level assembly it only shows some of the files in its assembly. If you then go "Open in New Window" it shows all of the components (as CGRs) exactly as you would expect.
Is there a setting somewhere that is limiting the number of CGR's displayed in the parent assembly?
Munners
