API Programming (post processing).
Hi guys,
I hope someone here can help me out with API programming. I looked through the femap forum here and all the API threads are very old and outdated so thats why i am opening a new thread. I made a macro that's suppose to change some nodes and element (loop) and rerun the analysis multiple times depending on the number of changes. The problem is that if there are more than 50 analysis FEMAP/my computer crashes. What I was looking for was some function to make sure the analysis are after the previous one has been completed. I'm currently reading into "FeEvent" but since I'm new to the whole programming gig, its all blur at the moment. Any help will be much appreciated. Thank you in advance
Marvin Gopal
RE: API Programming (post processing).
Hi Marvin,
My first thought was that I'm surprised you made it to 50 analyses before your computer crashed! I assume that when you run the analysis it is running in FEMAP, and when it finishes it imports the results? It depends on the size of your model, but that could be just too much data for one file. I would save each iteration as a different model and just export the analysis files (.dat or .nas or whatever) to run in a batch outside of FEMAP. Then you can import each result file into the corresponding .modfem file.
However, your specific question was about waiting for the run to finish. I have never used FeEvent, or ran an analysis from an API, but I have imported results and waited for that to complete before moving on. It looked like this:
'import Output file
App.feFileReadNastranResults(8,op2Title)
Do While App.feFileProgramRunning()= FE_OK
Wait(2)
Loop
This is in chapter 3.18 File Utility Methods of the api.pdf. feFileExecute might also work, since you can ask it to wait until the program has finished running.
Hope this helps!
