Applying new boundary conditions
I would like to perform an analysis so that the first step is static and the second step applies a harmonic vibration. Nodes are displaced in the first step. I would like to constrain some nodes to the position they end up in after the first step to their "new position" for the proceding steady state analysis step. Help?
RE: Applying new boundary conditions
use the *boundary, FIXED keyword
Thanks, but it didnt work.
In what way? They moved? You got an error?
If you know those nodes needed to be constrained initially, you can easily apply a boundary condition which is activated in the second step only. In case the nodes will be displaced at the firs step and the BC will be applied at that position.
Otherwise you can define a new step between your steps and find out those nodes to be constrained and brought them back in the new position, which will be not propagated on the third step.
If in the first step I displace node A 1" in the 1 direction, node B translates n inches in the 2 direction. In the second step when I apply
*boundary, fixed
nodeB, 2
node B is translated back to node B's original position.
