Epoxy grout with aluminum anchors
Can anyone recommend an appropriate epoxy grout that could be used in contact with mill finish aluminum such that corrosion or other degradation of the aluminum will not occur? Evidently cement grout is not a good application for this.
Thank you
Thank you
RE: Epoxy grout with aluminum anchors
http://www.eng-tips.com/viewthread.cfm?qid=146335
