Rheostat on single phase induction motor
Can you use a rheostat to control the speed on a single phase(PSC), fractional horsepower motor? If so, how does it control speed without changing the frequency?
RE: Rheostat on single phase induction motor
You can do it on motors with a high rotor resistance. You simply increase slip when you change voltage. A triac or a transformer with taps (or Variac) is more often used than a resistor. Suitable for fans and ventilators where power is speed^3
Gunnar Englund
www.gke.org
If you lower voltage you will increase slip. You are not controlling speed. Not practical at all.
It is being done all the time.
Gunnar Englund
www.gke.org
As Gunnar said, it is a pretty common method to control fans (like ceiling fans). The torque required to turn a fan increases very rapidly with speed so a rheostat (or capacitor) which limits torque will reduce speed. The high rotor resistance keeps the motor from overheating at high slip.
Stator side resistor works for NEMA Design D motor which has a curve of torque vs slip which is monotonically increasing.
Would not work nearly as well with typical NEMA Design B motor with a breakdown torque peak a few percent below sync speed.
(2B)+(2B)' ?
Brad even though it's done on fans that doesn't mean it will work in any other application - it won't. However you haven't said what your application is.
Keith Cress
Thanks everybody. This is for a fan application.
