Criteria Plot
Criteria Plot
When I plot criteria stress values, I get maximum value labels on each element. Is there a way to plot average values?
I've been going through the different menues and can't find a way to do this.
Thank you,
W
Thank you,
W
RE: Criteria Plot
if you want element average, why not use that field ?
if you want to be sure about what's being plotted, look at the f06 file ... you'll see nodal stresses and element (average) stress.
RE: Criteria Plot
I'm able to display avg stress but only on the most critical elements (max/min), I'd like to have this value on all elements of my model, again, similar to the view I get from a criteria plot.
Do you know a way to display this?
Thank you,
Ww
RE: Criteria Plot
you want element values ? that's what i get with "criteria view" (i think the contour plot shows only the extreme values)
and it looks like it's showing the element average stress ?
but if only some of the model is plotting, maybe you've got only some groups active ??
RE: Criteria Plot
I want the same as the criteria plot, but instead of showing max values (on elements) I want average values.
I hope this is more clear.
W
RE: Criteria Plot
i had a contour plot, and clicked the criteria button and got element values ... ??
RE: Criteria Plot
RE: Criteria Plot
for a tpyical element i had nodal values between 11.9 ksi and 12.5 ksi, and an element value of 12.2 ksi
