NX7.5 - BLEND TOPIC
NX7.5 - BLEND TOPIC
Please, see the attachment:
I need to blend the yellow faces of the Swept4, on the long edges (on the left and right of the text ‘EDGE”).
But I can’t!
Can somebody tell me why?
Certainly, there’s a connection between Swept and Blend, but I do not get it……..
But I can’t!
RE: NX7.5 - BLEND TOPIC
The swept command is often used to transition from one shape to another. To do this it will often convert the input sections to splines. In cases like yours, you want to sweep a constant shape along a freeform guide; using "preserve shape" will keep the hard edges you need.
www.nxjournaling.com
If you try add a smaller blend than the minimum radius found on this face, it will most probably fit without complaints.
When sweeping profiles like this, turn on the "preserve shape" , else NX will create only two faces for the profile, and then the modeling distance tolerance will dictate how small/big this "ridge" will become. ( Try set the tolerance to ~ 1/4 the width of the profile)
Tomas
Thanks!
