Export assembly to parasolid with names
We have NX 6 and TC2005 and I'd like to export selected solids from an assembly outside teamcenter and keep the names on the solid. So I'd like to be able to select bodies and select the destination folder. I've found journal files here that do one or the other, but not both. The one below has the select folder option, but includes hidden solids.
thread561-290743: Writing Journals: Export solid models
RE: Export assembly to parasolid with names
Does the solid selection
www.nxjournaling.com
I managed to get the first script to output to a specified folder, but I only got the revision letter added to the names.
thread561-316531: Parasolid Export Naming
I don't have TC to test with, so post back with any errors you encounter; I'll try to fix them as best I can.
