Zoom and center part in screen
Is there a way to zoom and center a selected or active part (sorry dont know correct words, as my installation is not english) in one click? (menu, mouse, function key)
Thank you in advance
RE: Zoom and center part in screen
There is a command called "Fit view to selection" that will zoom in on whatever you have selected at the time. In NX8 it can be found in the View -> Operation menu. The exact location may depend on your version, if I remember correctly, older versions didn't have it in the menu by default (even when running full menus).
www.nxjournaling.com
It does what i think you are looking for as long as the selected object has " a bounding box". - Not all objects has that but components and solids do.
Tomas
