Selecting with tables - stresses
I have a model and I'm trying to select certain frames which are within a specified stress range. I can get the table to display the items I want through the Display > Tables command and then filtering and sorting, but from here, I cannot select the frames.
If I try to use the Select > By Tables command, then I cannot get to the frame stresses.
Does anybody have any suggestions? Thanks.
RE: Selecting with tables - stresses
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
