Checkered Plate Floor Diaphram & Lateral Bracing
I'm designing a floor with 5/16" checkered plate. I have two questions:
1: Does the checkered plate provide any diaphragm action?
2: Does checkered plate typically provide adequate strength and stiffness to be considered lateral bracing for the floor beams?
RE: Checkered Plate Floor Diaphram & Lateral Bracing
It can be checked for strength and stiffness using AISC 13th Appendix 6.
