The soft tissue is connected to the
The soft tissue is connected to the bones with tie constraints. I'm having better luck getting it to solve when I turn off "adjust slave surface initial position". This to me suggests that the fragility of the model is in fact due to the warped elements. I will continue to improve the mesh structure. Abaqus is frustrating in that two versions of a model can run with the exact same warnings, but one converges while the other does not...
I seem to be on the right track for now, thanks for your help, once again!
Sam
RE: The soft tissue is connected to the
Woops, that was supposed to be a response to another post, not a new post!
