SF6 "Voltage Transformers" in HV (150 kV) lines
RE: SF6 "Voltage Transformers" in HV (150 kV) lines
Sempronio1960,
SF6 inductive voltage transformers (IVTs) are much less prone to explosion if compared to oil-insulated capacitive voltage transformers (CVTs).
However, for sake of safety, we now specify only silicon rubber for outer insulation: the risk for working personnel is then considerably reduced even with conventional CVTs. Thus we foresee IVTs only on cable lines and for energy metering purposes.
Si duri puer ingeni videtur,
preconem facias vel architectum.
