SURFACE DEFINITION ASSEMBLY__PICKEDSURF not found
Does anyone know what this error is?
SURFACE DEFINITION ASSEMBLY__PICKEDSURF234 NOT FOUND.
SURFACE DEFINITION ASSEMBLY__PICKEDSURF237 NOT FOUND.
THE SURFACE ASSEMBLY__PICKEDSURF234 HAS NOT BEEN LOCATED
THE SURFACE ASSEMBLY__PICKEDSURF237 HAS NOT BEEN LOCATED
I can see that the last 2 propagates from the first 2 errors, but exactly what is the surface definition assembly?
I've had this error in the past and usually solved it by remaking the model. That is out of question on this particular job.
RE: SURFACE DEFINITION ASSEMBLY__PICKEDSURF not found
