Using a ASME section VIII vertical vessel as a horizontal vessel (R Stamp)
My company recently received their R stamp certification, and we were wondering if by changing an originally vertical vessel into a horizontal one (because we want to utilize it in a different process), would that be considered a repair or an alteration? We will also have to weld new saddles, but the nozzles we are adding are going to be the same size as existing.
Thank you,
Adam
Thank you,
Adam
RE: Using a ASME section VIII vertical vessel as a horizontal vessel (R Stamp)
Cheers,
gr2vessels
Cheers,
gr2vessels
