ER70S-G
ER70S-G
Dear All,
Here I request your valuable help. My question is
"Why ER70S-G,used for GTAW, is less preferred (and sometimes treated banned) ?"
I am currently reviewing a proposed WPS with the same filler metal. Once again I request your guidance and support.
Thanking for your valuable time,
Harikrishnan K A
RE: ER70S-G
Because when the weld wire is specified with a G designator this means the properties of the wire are agreed upon between the Purchaser and the supplier.
RE: ER70S-G
Add to metengr: and the chemistry may or may not essentially match that of the base metals to be joined and will vary from supplier to supplier.
