asme b31.3 test pressure
Hi we have cooling water on site. Some of it is safety classified Cat M and some just normal process water. When doing hydro tests on both the systems is there any difference or are they all at 1.5 the design pressure?
RE: asme b31.3 test pressure
Suggest you have a look in Category M - the answer is quite easy to find.
You will not learn anything by posting a question without having a look first,
Kiwi
