Creating assembly for release on the web
Hello, I would like to ask how can I adjust the assembly so that it can be offer on our web to designers for the purpose of inserting into their project without possibility to see "inside" or to dismantle it by the reason of loss own know-how (version - Solid Edge v20) Thank you very much.
RE: Creating assembly for release on the web
There is actually a 'tip' for this at least in V19.
Change your select type at top left to 'select visible parts', then do a show only, then do save as step (or iges etc.) and set the option to process only visible parts.
Or something like that.
This obviously only helps if it's only truly internal detail you care about hiding.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
