BALLOON SIZE
BALLOON SIZE
BALLOON SIZE
IS IT POSSIBLE TO SET-UP THE BALLOON SIZE TO BE THE SAME WITH ONE OR TWO DIGITS NUMBER.
THANK
RE: BALLOON SIZE
If you are refering to Catia V4, I put a space in the text before the single digit number. The text will be set to the oneside, but looks better than different size balloons.
RE: BALLOON SIZE
In V4, Balloon sizes are defined under the DRWSTD function. Their size can be defined as dependent on the text size, or a fixed diameter as you requested. They are stored in the project file and you need write access to change or define them.
