Friction in ADV Nonlinear Analysis
Hi
Anyone knows if it is possible to apply a time function to a frictional contact properties in a sol 601 ?
I would like to start for the first time step with a frictionless model and at the end i should introduce the friction.
I need this behavior to simulate the correct mounting procedure.
Thank you
Thank you
