Friction in ADV Nonlinear Analysis FEMAP - NX NASTRAN
Hi
Anyone knows if it is possible to apply a time function to a frictional contact properties in a sol 601 ?
I would like to start for the first time step with a frictionless model and at the end i should introduce the friction.
I need this behavior to simulate the correct mounting procedure.
Thank you
RE: Friction in ADV Nonlinear Analysis FEMAP - NX NASTRAN
Dear Firema,
You can use RESTART, you can run till the time step you like, then stop the analysis, modify the contact properties, time step size, final time, etc.. and re-run your model using RESTART.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
Dear Blas
You are right I have done in that way and it works.
Thank you and BR
