dilute ammonia corrosion 304
Hello
Are alloys like 304 / 304L suitable with dilute ammonia / ammonium sulfate solutions, at pH 9 and at 40-80°C temperature range. It's for a heat exchanger.
Concentration will be low (<0.5 gram/liter NH3/NH4+)
other species present SO4--, Na+
Chlorides: less than 0.2 gm/liter
RE: dilute ammonia corrosion 304
Mostly safe, but with a couple of details
1. If you allow flow to stop and the unit does not remain completely full then the surfaces that dry will probably pit.
2. 200ppm is a lot of chloride for 304. As long as the pH is high you should be OK, but this is pushing the limits.
Plymouth Tube
Thank You
Stress corrosion cracking issues from the H components?
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
